- Jan 17, 2016
- 11,672
- 18,770
- 14 Sport
- 5.7
Common sense should have told you where the piece originated from,and that same common sense should of told you,there has to be someway the oil has to get back to the oilpan after it's been pumped up to the heads,and common sense should tell you,that there must be oil drain back holes in the block.With that i'm out,good luck on your adventure.That was the point of me taking the pan off. Why wouldn’t I worry about that as well.
