Claydus
- Jan 26, 2023
- 35
- 16
- Location
- Ducktown, GA
- 2020 RAM Rebel
- Hemi 5.7
As the title says, my new to me 2020 RAM has a slight issue when opening the passenger door. It rubs the front fender and some paint is chipping off the door. I noticed it this weekend just 3 days after buying the truck.
It appears that the middle and bottom alignment of the fender is not lining up 100% with the door. Or possibly the door isn't lining up with the fender. However, the gaps and measurements between the front and rear passenger door have same gap and alignment from what I can tell. So I am leaning toward the fender being the issue.
I have contacted the dealer to see what can be done about this.
Door closed. Wide shot.
Door closed. Zoomed in. You can almost see how higher the door sits above fender right here.
Opening door. Zoomed in door rubbing.
Straight edge measurements at middle.
This measurement looks fine. Driver side looks like this all the way down.
Straight edge measurements at bottom.
