You need to be
extremely careful about this if you require a specific payload. I was looking for a truck to replace my SUV because I wanted to purchase a Travel Trailer. A 2500 or larger model wasn't in the cards for me because they simply were too large height-wise to fit into my garage. So, I went to the Towing Capacity page on the RAM website and looked up the RAM 1500 Limited. Here's was it said:
1790 lbs was more than enough payload for the trailer that I wanted. Now, keep in mind that the Limited comes
loaded with most options standard. So, naturally, I thought that this was figured into in the above payload. The only extra options I had were the MFT, the sunroof, and these:
Except for the MFT and sunroof, the rest were options that didn't
seem to add a lot of weight. Mostly electronics and color changes.
When it came down to making a deal, I had only an hour or so to decide on the 2021 Limited I found because someone else was just about to put a deposit on it and the deal was just too good to pass up. So, I failed to look up the actual payload via the VIN. I was figuring a couple of hundred pounds more or less.
Well, I was wrong, it was
634 lbs less, bringing the payload down from 1790 lbs to only 1156 lbs. Now I'm having problems finding a travel trailer in that payload range.
Lesson learned. Don't make the same mistake. Always check the payload via the VIN
before you buy.
