Pedal Commander
lharrell79
Also, on page 1, you said the same effect can be had from tipping in more? What does that mean? How do I tip in more?
Moab_Rockstar
Lake Orion, MI
5.9L
I'm trying to understand how the throttle by wire works. On my old Jeep, it was throttle by cable. If I mashed the throttle, it was instant response. With my truck, it is not. If I mash the throttle, there is a delay, and a slow ramp up in throttle. Why does this happen on my truck, and not on my old Jeep?
It's pretty much all perception.
In a cable throttle, your pedal is directly connected to the throttle. When you open it, air goes in instantaneously. In a carburetor fueling happens at the same time. With fuel injection, the computer is using TPS and MAP or MAF to calculate airflow and decide the necessary ignition timing.
In drive by wire, the pedal signal goes to the PCM as a voltage signal, and has to calculated to a torque request. There are a couple calculations it has to go through to become a torque request. The PCM then runs that request through an arbitration where other torque requests are compared. Generally, whatever request is "safest" becomes the actual request. With the actual request determined, the PCM then commands the fueling and timing for that loop.
The additional calculations all add up eventually, but for the most part the lag is more perception than fact. In the cable throttle, you open the throttle immediately and you can hear the change in the sound of the engine but it's not really making more power yet. Fuel/air is still on it's way to the cylinders. In a drive by wire, you hit the pedal, and the engine runs some calculations, then the throttle opens and the engine makes more power. In reality the difference in actual engine response between the two is actually fairly minimal, probably on the order or 40-50ms. The difference in an electronic throttle is that that throttle opens when the engine is ready, whereas in a cable throttle, it opens first, and everything else is reactionary.
Every muscle car I've ever driven, whether it's carbureted or electronically controlled, there's always been a lag between pedal to the floor, and being pushed back in the seat. The lag is due to the time it takes fuel and air getting to the cylinders. It seems faster in the carbureted car, because I get a more direct feedback in my perception as things change with the vehicle. The electronically controlled throttle does it more efficiently, so it doesn't seem as responsive.
Moab_Rockstar
Lake Orion, MI
5.9L
Apply the pedal more or faster. For a lot of people it probably isn't possible to go to full pedal in 80ms. But if they did it in 160ms, I'm not sure how much you'd really be able notice.
J
jaflowers
6.4 hemi
There is no "seems" or "perception" when it comes to what this little device is doing, period. I push the gas normally from a stop and the truck perks right up almost instantly and accelerates up to speed better. I understand it doesn't increase HP/TQ but it radically changes the throttle response to the computer, depending on how you set it. That's not perceived, that's what it does.
When I turn the PC off, the throttle response goes back to the same old way that it's been since I bought it.
I'm not an easy sell on gadgets. As an engineer I'm always skeptical. This thing actually makes the truck respond better and perform to my liking. If it was bogus, or if I thought the performance was just between my ears, it would go back immediately. I've had a tuner before on my last truck and it was great and made a noticeable difference in drivability. Since I didn't want to spend the extra money buying a new computer for this truck as you can't reprogram a 2015, I thought this device might work. I must say all the reviews I read before buying it proved true and I'm happy with the relatively little money that this cost for the better drivability.
SouthTexan
408 CTD
In the end, you being happy with it is all that matters. It is your money and you spent it on something that made your driving experience more enjoyable by customizing your truck to your liking. Some people like a sensitive throttle, some don't. It is no different than someone spending thousands on a 6 inch lift for looks alone even though it really doesn't add any more off road capability for how they use their truck. What matters is that you like it since it is your money and your truck, others can just go pound sand.
lharrell79
When you say that the throttle by wire lag is a perception, I'm going to have to disagree with you 100%. There is more to it than that.
My Jeep, 98 TJ 4.0, throttle by cable. If I cruise along at 10 mph and nail the gas, I get instant full thottle, and it smokes the tires off. Immediately.
My Ram, 08 1500 4.7, throttle by wire. If I cruise along at 10 mph and nail the gas, I get a delay, and then full power. It is about a 1 second delay. It is not a perceived delay, it is an actual delay.
With the throttle by wire, there has to be a slow down in the process somewhere.
Moab_Rockstar
Lake Orion, MI
5.9L
Your comparisons aren't even comparable. You're comparing a full size truck that weighs at least 4500 lbs to a Wrangler that weighs about 65% as much. In addition, when you're rolling at 10 mph, you are not going to be in 1st gear. If the pedal goes to WOT, the trans is going to downshift. In the Jeep you have a TV cable going to the trans that essentially forces it to downshift, in the Ram, the trans logic in the PCM has to determine that it needs to downshift, which has a bunch of logic that the torque requests have to go through, because to shift, the trans needs a specific amount of torque, so yea, it's going to be slower.
The fact that someone would think the device is really making the PCM react faster is due to the unit is simply faster than you. It's probably getting to WOT pedal at 100ms, where your foot is doing it around 300-200ms. If you applied the same pedal voltage with your foot that the device did the same amount of time, there'd be no difference.
So if you really want a faster pedal response, and want to spend the money on it, go ahead. Just don't expect more performance.
lharrell79
Okay, so essentially, if I cut the length of the pedal shorter, it would do the same thing? A shorter pedal would make the TPS respond quicker? The pedal commander amplifies the TPS signal?
Moab_Rockstar
Lake Orion, MI
5.9L
Not TPS, that's the position of the throttle, pedal is PVS. Pedal Commander and the equivalent change the PVS voltage.
A shorter stroke on the pedal might result in voltage changing faster, I don't know if it'd be feasible.
