pedal commander
Nick@GotExhaust
Supporting Vendor
SC
I am still on the fence on the PC -please someone push me to one side or the other!!
Easy install, literally takes like a minute or 2 tops. easy removal if necessary. It gives great everyday drive ability. seat of the pants feel is very noticeable. The great part about it is the ability to change settings as needed when ever needed. So you can crank it up when you want to hot rod around or turn it down for heavy traffic city driving and then some where in the middle for around town. We have sold tons of these. This is not just some gimmick that will never be heard of again. We sell more of these every year than most other mods. I have one in my personal truck and love it!
Look, this is single-handly the best mod you can do for your truck. Plugs into top of oem accel pedal and then the oem wire plugs into the opposite side of harness.
Set it to Sport, +1. You will SMILE YOUR ASS OFF. It cuts down on your pedal lag by 100%. Whether from a dead start or kickdown passing on the highway. If you pull up your Pedal Commander equipped Ram next to a non-equipped at a stoplight you will absolutely holeshot the other one. Its electronics are faster than any human foot press could be. Removes in seconds for dealer trips and leaves no trace on computer.
Well said!
Nick@GotExhaust
Supporting Vendor
SC
Lucy Girl
Military, Army Veteran
Mt. Vernon, Texas. 75457
3.6 V6
It gets rid of the throttle lag. It makes the truck much more responsive and is fully adjustable so you can find the sweet spot for your driving. Its easy to install and easy to use.
Let me know if you have any questions
we have them listed here for more info and for ordering
https://gotexhaust.com/i-23645471-2...ottle-response-controller-pc31-bluetooth.html
be sure to use promo code PC5 for a discount!
Thanks much for the information. Do you know how much they cost. Sounds inviting
Nick@GotExhaust
Supporting Vendor
SC
Pull Ya
Cedar Creek, Tx
See if any of your friends that have a Ram have one installed and ride with them to see what you think. The difference in acceleration is extreme. That should help with your hesitation problem(so to speak)
Jay
indept
South Jersey
Jay
There are 36 levels 9 in economy mode and 27 above stock response.
indept
South Jersey
My only complaint with the PC is the velcro doesn't stick to the dash. And yes, I cleaned it with the alcohol wipe that came with it first. I even bought extra strong velcro from Home Depot and that falls off too.
16Ram4x4
Missouri
I also have a pedal commander and really like how it makes the truck feel. I also had issues with the supplied velcro not sticking. My solution was to use some high end trim tape and stick that to the back of the mounting bracket, then stick the velcro to the trim tape on your bracket. Then I did the same thing for the velcro on the dash location. So far it hasn't fallen off and that was 2 1/2 years ago
indept
South Jersey
What brand "high end" tape did you use?
Pull Ya
Cedar Creek, Tx
"Gorilla" tapes is advertised as the best there is----LOL
Jay
16Ram4x4
Missouri
3M trim tape grey in color. It also helps if you heat it up with a hair dryer and stick the velcro onto it and press down for a little bit, then let it cool down before putting a load on it.
JohnnyMac
SouthWest Washington
2018 1500 Laramie / 2024 3500 MegaCab Laramie
3.0 EcoBurner / 6.7 Cummins HO
It's pretty much a must have for the EcoDiesel. Got rid of most all of the turbo lag. I run Sport +2.
