I just joined Ram Forum today specifically because I found this post when doing research for a problem I'm having.
I've got a 2014 Big Horn with 5.7 HEMI and 8 spd trans. I love everything about the truck EXCEPT the throttle response. I find the gas pedal to be overly sensitive and the power curve uneven.... For lack of better words it's hard for you to feed the power in from a complete stop. I have to be extremely light footed on the gas to get it started smoothly, otherwise it either jerks you back, or sometimes even breaks the rears loose a little. It's starting to wear on me. A lot. I know the system is now fly by wire and that seemed to be a huge complaint. Basically I want my gas pedal to feel more as if it was an old direct cable linkage assembly (the pedal to have more resistance to it) if that makes any sense.
In doing my research I've found people have suggested both the Diablo Sport tuner i2, ornthe Pedal Commander for throttle issues. So with that in mind I have two questions:
A) Does anyone else have the same problem?
B) Does anyone here have familiarity with the DS i2 tuner/Pedal Commander and if so, pros/cons, do you think it will help?
Any constructive feedback is appreciated. Thanks!
