BlueMule
2017 2500 with factory 33's. I installed 37" tires several years ago with 4.88 gears front/back. Never thought about the spare tire until I had a rear tire blowout about 80 miles from home this past spring. At the time of changing to the 33" spare, I rotated a 37" front tire to the rear axle where the flat was, and put the 33" spare on the front so to even out the rear drive axle differential gears. But this begs the question; did having a 33" and a 37" tire on the front axle cause any undue wear to the front differential gear? (This then brings up the question of what kind of differential does the 4th Gen 2500 have in the front? Open?) And if it did cause wear, this would then justify having a 37" spare. Anybody running a 37" spare?
