Perfect Excuse For Headers
jtoscano19
Mcallen, TX
I was just told my exhaust manifold gasket is leaking alittle and since they're gonna take everything off to replace the gasket..might as well put in some headers! Which ones would give me the most low end power?
glass3222
Central PA
How much do you want to spend? Do you want direct bolt in replacements? Do you have emissions testing where you live?
badfish888
Va beach
2012 hemi express
i loved my bbk shorties, i felt a noticeable low end gain, plus there a direct bolt in
jtoscano19
jtoscano19
Mcallen, TX
around 600 installed if thats possible, I do have inspection but I know a guy. direct bolt on would be easier to install
Bigdaddy
2022 3500 Laramie CCLB
6.7L Diesel Cummins
glass3222
Central PA
For 600, you are pretty limited. BBKs are about 300-400, install will probably be at least 100, most shops will be more than that.
jtoscano19
jtoscano19
Mcallen, TX
I think I'm going with the bbk shorties..do i go catless? and will I need a tune?
MADDOG
Living in a Firepit
Don't go catless and you will not need a tune.
Look at JBA headers as well before you make a final decision.
Use good quality gaskets and some Stage 8 fasteners vs. re-using your stock manifold bolts.
Budakane
Northern VA
345ci Hemi
hit up Duane at 3rdstrikeperformance...he will hook you up.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Shorties would be the easiest and direct replacement basicaly. Make sure you order a new set of Mopar gaskets also when you do it, the ones all the companys use are crap.
glass3222
Central PA
I may be wrong, but I think JBA only made headers for 03-05 hemis
Pacesetter Long Tubes FTMFW!!!!!!!
I agree, but no way will you be able to get them for 600 installed IMO.
^^^yep
the codes
Houston, Tx
Magnum 5.2
I hear alot of good about jba, with mad dog on stage 8's
Tapatalk Addict
jtoscano19
jtoscano19
Mcallen, TX
Yeah I talked to my friend, he's a mechanic at the dealership and he said we could work on it on a weekend at his house
Picton
Houston, Texas
2015 - 1500 Express CC 4x2
Installed JBA Cat4ward shorties on mine...love them...Stage 8 fasteners FTW!
stevenmicheal
