Nice looking truck man, yes they are the 1 and 1/2 inch springs and my wheels are +18 offset. I'm not sure if they will fit with - neg offset wheel but it's worth a try.@Sdreeser Pimpn Truck, Are your springs the Thuren + 1 1/2"?
And then how about your wheel offset? Will these be the same wheels and Same offset You will run with the 37" tire?
I'm prepping for a similar setup, hope to pull the trigg as soon as I know where to aim. I recently completed a gear swap to 5:13 from the OE 4:10 ratio, and the lift is next but I'm not absolutely sure how much lift I need in order to fit the 37" with my -25 mm offset stance. I'm Thinking 37x13.5 x18.
I see Thuren states that 37" tires will fit with stock P.W. lift with a +18 mm offset but I would rather not buy new wheels right now.
Anyway, anything You can share is much appreciated.
Here's mine:
Sent from my SM-N950U using Tapatalk
Ok have the Thuren front springs on and front track bar with fox reservoir shocks. Here is a pic of stance on truck now.
That is the aeroskin II.Nice looking truck!.. Who's front bug guard are you running?
Rides really well. Much better and a bit softer over bumps than stock setup.wow that looks great, how's it ride now?
Yes they are the 1.5 inch springs. You will love themNice looking trucks still waiting on mine to ship are those the 1.5” springs?
