Picked The Wrong Tire/Size?
Magnum5.9
01 ram 1500 4x4
Magnum 5.9
I went from 285/75/16 Aturo trailblades (has rims protector) to 275/60/20 BFG ko2 (does not have rim protector.
I do not offroad much but when I do I go easy but my current setup is concerning me. I stuck a 2x4 up against the side wall of the tire and the 20x9 tires only sits behind the sidewall by about 3/4" and the KO2s do not have a rim protector design.
I have 30 days with discount tire to swap into a different tire for minimal charges so im either thinking of going to the duratrac in the same size because it has the rim protector or the much more expensive route would be to go to a 285/60 or 305/55 to gain the extra width to protect the rim. But going to a larger size means E rated tires which is heavier and harder on front susoension/steering ( setup all ready heavy enough being 20" rims).
What is your guys thought on the 275/60/20 duratracs with the rim protector? (This size is only 115s rated not D or E rated so I would lose potential tire/side wall strength)....
roastpuff
I have the same tires - not worried about the rims, I am not rock climbing so I doubt that the rims would get scratched/gouged.
I would take the tread and the stronger sidewall of the KO2.
M
Magnum5.9
01 ram 1500 4x4
Magnum 5.9
Ok thanks for the info! Anyone else have some thoughts?
M
Magnum5.9
01 ram 1500 4x4
Magnum 5.9
Anyone else?
LaurenMagnum360
Illinois
360 V8
I have 255/85/16 BFG MT KM2's and love them. It's E rated, holds up to 85 psi so i'm not worried about puncturing it at all.
M
Magnum5.9
01 ram 1500 4x4
Magnum 5.9
No one else?
mitchbowers
Ohio
1996 2500 5-speed, soon to be leveled on 33's
5.9 Magnum
If you're only doing some mild trail riding i wouldn't worry about it.
agree here. unless you're going into some stuff you obviously shouldn't be if you want to keep everything nice, then I don't think you'll have a problem. the ko2s are a nice tire. and as many tires as I see at the shop, you'll see more damage to rims from not taking proper care of them(never washing them) rather than scratching from brush. and those people usually just beat the hell out of their trucks lol
it's more of a personal choice here, I just think of something is going to scratch your rims it will probably do it regardless of tire.
Sent from my XT1575 using Tapatalk
M
Magnum5.9
01 ram 1500 4x4
Magnum 5.9
Bump... need to make my decision soon
TheM4rxxx
