Looks like a leak to me. Does it smell like grease? Keep an eye on it and the grease level in the diff.
Have you ever had a pinion gear go out? My '01 rear pinion let go once. I must have been living right because I was less than a mile from the Aamco that rebuilt my 46RE. I had stopped at an intersection and noticed some blue smoke drift past me and I smelled the grease. By the time I got into the Aamco parking lot, grease was pouring out around the seal. From my experience, if you begin to hear a whine when you let off the accelerator to coast, it won't be long before it goes. Mine went within a week.
its a leak. if your mechanically inclined theyre pretty easy to change yourself but since your asking if its even a leak , youll need to go to a dealer. hopefully they do it right. otherwise you may be going back for a new gearset
I’m asking if it’s a leak because I’m in disbelief that my nearly brand new truck is already leaking at the pinion, but thanks for the insult.
ive seen them leak with 200mi. **** happens. atleast you dont have a bad case of death wobble like alot of the new fords have
