PlastiDip Concerns
hackercity
HEMI 5.7
I dont know if I applied it correctly, but I sprayed my chrome emblems and handles with plastidip.
It looked pretty EPIC!!! When I say looked I say that because the door handles I painted were starting to come off after getting in and out of my truck in 1 day. My emblems grabbed all my towel lint and started coming off too.
I was thinking of spraying my chrome grill and bumpers. After seeing it start coming off the places I already sprayed made me think if it was a waste of time to do the rest.
I see guys on here spray everything including wheels and I am wondering if anyone has this issue.
Maybe I am doing something wrong.
I cleaned the surface with soap and water. dried it. I actually used a heat gun to make sure it was dry. Spayed a coat used the heat gun on low and held it about 10 inches away. let it dry an additional 20 minutes between coats. a total of five coats. Thick enough I almost started losing the edges of the emblems.
Anyone else have this issue?
Any suggestions?
Thanks,
ram-head
Arkansas
I was able to rub it off rather easily on the wheels of my 2007. They were aluminum alloy, and were cleaned with brake cleaner and a microfiber cloth. I view PlastiDip as more of a method of seeing if you like the look of something black without committing to permanent paint.
gmzvip23
2k12
hmm could of been a bad can. Is it cold temps where your spraying?
craigsez
Novascotia,Canada
Got it on my grill and all four wheels but the back didnt stay on long with the snow and salt here in eastern canada..The front and grill are perfect and i did it last fall..
hackercity
hackercity
HEMI 5.7
How many coats did you do on the grill? When you washed it no edges peeled... If it lasted even a few months I would do it.
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
I did my front and rear emblems last summer, many,many washes, still there.
jbmb06
chester il
I did my grill and all my badges 4-5 months ago and it still looks good, I put 4 coats on them all
hackercity
hackercity
HEMI 5.7
how did u prep it
I used soap and water. Cleaned it. Used a heat gun to make sure it was dry. I sprayed a coat. On everything badges and handles. Then went over it with the heat gun on low holding it about 10 inches away. Let sit for another 20 minutes.
I did this for 5 coats...
Sent from my SCH-I535 using Tapatalk 2
BlackedOutHemi
DFW, Texas
2012 & 2012
5.7L HEMI & 6.7L Cummins
So you let each coat dry in between? For some reason, it being the "plastic (rubberish)" spray that it is I would believe the coat still needs to be wet when you put on another coat so they can mold together. I could be wrong, but seems logical in my head. Lol.
rileybrennan
Saskatchewan
All I used for my wheels was a degreaser and windex I think. Lasted all winter just a couple spots where a piece the size of a dime has peeled. My badges I did the same and they have kept perfectly intact. I try to keep the pressure washer far away when washing too.
bizzbuzz21
Eastern Shore, Va
I tried a heat gun on my front emblems and it came out like ****. Peeled it off and redid it, let it dry naturally and came out awesome.
shostopper17
Next time or when you redo it use an alcohoal or they sell a plasti dip pre spray used that and all my plasti dip parts are still good been through 2 winters in mass
