snoty
- Oct 30, 2017
- 92
- 71
- Location
- Orange County, California
- 2016
- 5.7
Couldn't find too many people who have done this or at least any information on it, so I went for it! Thought the front of my truck had too much chrome since I replaced the stock chrome rims with matching color rims right after I got it. Not sure how well the PlastiDip will hold up but it has me confident that I like it and I can take the inserts to a paint shop to have it done for good.
Supplies Used:
1 can Anthracite Grey PlastiDip
1 can Glossifier PlastiDip
Process to remove grill (wish I took more pictures or some notes... It's easy to figure out once you're there):
Pop hood. Remove 6? christmas tree plugs from plastic cover. Remove four bolts with 11mm? socket that holds in the grill. Give the grill a good tug and it pops right out.
Once you remove the grill you need to go through and remove the two black plastic air guides by popping out the tabs. Then you remove I think 12 screws holding on a black trim piece. Now you need to be very careful removing the grill inserts by popping out the tabs. I used a flat head screw drive to push down.
I painted the inserts with 30-45 minutes between each coat and did 4 coats of Anthracite Grey and 3 coats of Glossifier. I'm not sure why, but it has kind of a texture to it and I was expecting it to be smoother... no big deal though. Here's the pictures:
Grill Inserts out.
Painted.
Dirty truck but finished.
Old picture of truck but shows what the grill looked like before... 2016 Ram 1500 Larmie Crew Cab 5.7L Hemi
Supplies Used:
Grill Inserts out.
Painted.
