mikeberrys
- Jun 10, 2012
- 8
- 0
- 2006
- Hemi 5.7
Hey guys, here’s back story: Three weeks ago I was in the mud with my 2006 1500 mega cab 4x4, dropped the passenger front tire in a deep spot and got stuck. No tow hooks, unable to pull from the rear, so was winched from the sway bar. Unfortunately the end links were bent to hell and bushings pulled from frame. Power steering pump also squealing and hard to steer. (fluid level empty.) I left it parked for a week, mud and all. 2nd week: got to work. Washed the truck. Had to remove sway entirely due to its condition, added fluid in powersteering ( I will need to replace pump anyway) ordered pump, and end links, bushings. Still waiting for new parts I drove it around a few times then gradually I noticed a grinding noise, now it’s very noticeable, a constant grind, at speeds above 10 miles/hr. the faster I go it gets louder, I hear it coming from front passenger side. So I pulled the caliper, even wear on pads, no metal on metal, have the truck raised, very slight play both front wheels at 12o’clock 6o’clock, fluid level good on front and rear differential and transfer case. 4wd working fine. Just this constant grind while driving, different from power steering pump failure. Any Ideas?
