please help!
blandrum82
I have a 1998 dodge ram with a 5.2 liter engine, I have recently done a ton of updates to this thing and now I have a problem and could use some help. I have only owned the truck for about a month and so far have replaced all shocks with rancho 5000's, added a two inch suspension lift, 315/75/16 tires, replaced upper and lower ball joints, replaced sway bar end links and bushings, new rotors, calipers, front and rear brakes, new u-joints on the front axle, new wheel bearings, rear differential fluid replaced along with gasket, plugs, wires, distributor cap and rotor. Here is where I have the problem...swapped the cap and rotor and since the motor is running fine on idle but rough when given gas like a sputter or backfire. I have checked the firing order making sure wire by wire at least ten times to make sure that wasnt the problem. If anyone has any ideas on what I could have done wrong or what the problem could be the help would be greatly appreciated.
Brakelate
South/Central Utah
1. Did you get the correct heat range plugs?
2. Look around in the "Tech Area" and re-post this question under the appropriate section for the proper year of your truck, etc.
That will get you a much quicker, more accurate response from a wider range of owner / members with the same year/make/model.
Good luck. And Welcome!
mikep345
