Andrew Hansen
During my injector swap earlier today my hand hit a tiny hose as I was moving some cabling to the side. The hose is about 3/16 in diameter. As the hose was brittle, and pressurized with air, it snapped easy against my brake booster. A tiny hose comes out at the top of my firewall, and into a bigger hose, but then junctions to a smaller hose (which is the severed one), and down to just above the front drivers wheel well. Can someone identify what this hose actually does and how i can fix it permanently. As a temporary fix, I used two pieces of heat shrink tubing on it, and it seems solid at the moment. I'm not sure how long it'll hold up though. I'm not sure of the PSI inside of the hose. Any info would be much appreciated.
