PO443 code
Dodgenerate
System has 4.9 v running to evap selinoid valve but not actuating. I tested it and it functions only when I use 9+volts so I bought a new one but still not opening.
I'm lost, any direction would be appreciated.
I tried clearing the code by disconnecting neg lead on Bart but still there.
1998 Dodge Ram 2500 5.9 gas
dudeman2009
2001 1500 Sport with enough electrical modifications to make my brain hurt
Magnum 360
How are you testing for voltage? Check from a known good ground like the battery negative post, or engine block.
