tones2SS
I agree with the brakes on the Ram,...they're ****. Mine have been squeaking since 14,000 miles and I'm now over 16,000 miles. Very poor, but that's the crappy materials that the vendor uses, but shame on Ram for using them. That all comes to cost.The build quality is the lowest I’ve every seen. It’s been in the shop more than all my other vehicles combined. My ‘63 CJ-5 was more reliable. My fuel sending unit failed, was replaced, and the new unit failed 1/2 mile away from the dealer. High failure rate of this part was a known problem several years before my truck was built and still is an issue. A week later the pcm in the truck died. The dealer took almost two weeks to fix it. While it was in the shop I drove an F150 made the same year as my truck. After driving it for two weeks I knew why the ram is the lowest priced truck. I didn’t want to give up the Ford, but had to. I was issued a GMC to drive for work. It proved to be a better built truck too. The ram is the only truck that I’ve had to do anything with the suspension to handle the tools I carry for work. I had to put TufTruck springs in the rear so the truck didn’t sag under the weight that other brands don’t sag under. The brakes are less effective than the other brands of trucks I’ve driven. I fixed that when it was time to replace the brakes. Problems I didn’t notice during the test drive. It was my mistake for not doing research before buying the truck. If I had I would have found that when I bought it the ram had the lowest payload and towing capacity of any of the half ton trucks on the market. It performs good as a car with a bed on it, but as a truck that’s actually used as a truck it doesn’t.
In all honesty, if my truck was totaled tomorrow, I would only be a little upset. I'd go order myself a 2019/2020 Ford Raptor in supercab configuration.
