I have power fold mirrors on my 2014 R/T and they fold anytime, including when the truck is off and I am standing outside.
Tazer appears to have the links f-d at the moment. The link in your post is to the bypass, and the link to the bypass is for the dongle...The only way to do it is with a "Tazer", a rather expensive ($250US) gadget that you have to leave connected to the OBD2 port. https://www.zautomotive.com/product/tazer-ram/
-K
I don't believe so. The reason being that Alpha can only alter functions that are built into the modules (door modules in this case). There is no such function in the door modules on a 4th Gen truck (unsure about 5th Gen) so Alpha can't do it and Tazer has to be attached to be able do it.Tazer appears to have the links f-d at the moment. The link in your post is to the bypass, and the link to the bypass is for the dongle...
I wonder if there is a way to do this with out having to leave a darn dongle in at all times, as Alfa can do the windows down from fob option as a programmed option...
Didn't mean to imply that ALFA could do it, but as a programmer, I was wondering if there was some other way to do more.I don't believe so. The reason being that Alpha can only alter functions that are built into the modules (door modules in this case). There is no such function in the door modules on a 4th Gen truck (unsure about 5th Gen) so Alpha can't do it and Tazer has to be attached to be able do it.
-K
Well, from a technical standpoint, I'd say yes, it could be done. I've had some ideas on the subject using one of the small boards with an ATSAME51 and CAN transceiver on board. If you could figure out the RAM CAN code for "Engine Off" and "Engine On" and monitor for them, you could send the door modules a fold or unfold command as needed. It would still need to be connected into the CAN Bus somewhere though of course.Didn't mean to imply that ALFA could do it, but as a programmer, I was wondering if there was some other way to do more.
