Adding to the thread.
I have successfully upgraded my 2011 and got the power folding mirrors to work. From what I can tell the 09-12 door modules never had the capability to use the feature. They are missing the pins in the connector. What I ended up using were modules from a Grand Cherokee, mirrors from a 2014 Laramie and a 2013-15 style window switch. Additionally I had to send my TIPM away from reprogramming. No new options show up on the EVIC but the mirrors will fold/unfold with key on. If anyone is interested I can post P/N's for the modules I used.
The backlighting color in the new switch was blue. I was able to swap the PCB from my current switch and retain my green backlighting. The old switch has the internal contact and software logic but the button is nonoperable.
This is a list of the parts we switch, in case you need to compare with yours. Again, beware that these might be different for your vehicle but this is just for reference.
** Power Chrome Trailer Tow Mirrors Part #'s:
Mirror Left: 68142673AD [GPC]
Mirror right: 68142672AD [GPC]
BRACKET,Trailer Tow Mirror Reinforcement:
Left: 68078243AA
Right: 68078242AA
NUT, Rivet, M6X1.00: 06507161AA (3 pcs.)
SCREW, Hex Head, M6x1x25: 06508709AA (3 pcs.)
Module Left: 68155771AD
Module Right: 68155770AD
** Power Multi-Function F/away Mirrors part #'s :
Mirror Left: 68231243AA
Mirror Right: 68231242AA
Module Left: 68155773AD
Module Right: 68155772AD
Driver's door switch: 68212784AA
Special thanks to everyone above. I used 1aauto power fold tow mirrors from 2015...
my 2011 ram has now factory power fold mirrors, i used a program called alfaodb to program my car and installed. wala power fold mirrors.... however i had auto down and up on the front windows. after install only auto down works.
took apart my OEM driver door module, found that i was receiving the voltage for power fold on the terminals however no terminals were installed. removed terminals from the one i just bought for driver side ( acctually removed 4, and installed in my OEM door modules.
my driver door went in. and worked my passenger didnt ( power fold ) but both mirrors had auto up and down.
reinstalled the new passenger door module ( the one pn above ) and both power folding mirrors and auto up and down is 100% functional !!!!!!!
so now i have one of the ONLY 2011 ram 1500s with power folding mirror from factory
working on getting the tow mirror sales code installed in the program i use ( alfaodb. ) so that when they are flipped they adj in the correct direction
i will later make a thread detailing what was done
