osprey92
- May 1, 2017
- 143
- 53
- 2017
- Hemi 5.7
I am replacing the stock, factory radio in a 2017 Ram 1500 Crew Cab, Tradesman with a 7" android head unit. The stock radio is the 3" radio/AM-FM/Sirus XM. I have the Android manufactures harness and I also purchased the XSVI-6523-NAV interface to make this as painless as possible. Well, it's been anything but. This is the second harness. The first attempt at install resulted in no power to the unit. I tested the unit off battery using the android wiring harness and the unit powers on and performs as it should. I ordered a second XSVI-6523-NAV harness and wired up the unit today and again, no power from the cab. I reseated the harness connection to the truck multiple times.
I've attached the wiring schematic from the radio and the CH3 interface harness. The wiring connections are made as follows, soldered and heat shrink wrapped:
Android CH3 Harness
Pwr Amp Taped off; not used
Steering Wheel Ctrl1 Taped off; not used
Steering Wheel Ctrl2 Taped off; not used
Brake Wire Light Green
Auto Ant Wire (to OEM antenna amplifier wire)
Rear View Green/purple
RLS- Green/black
RPS+ Green
RRS- Purple/Black
RRS+ Purple
Steering Wheel GND Taped off; not used
ILL Orange
ACC Red/Ignition
Ground Black
Power 12+V Yellow
FLS- White/Black
FLS+ White
FRS- Gray/Black
FRS+ Gray
Blue/White (amp); taped off
Blue Pink (VSS); taped off
Right now I prefer to focus on power, ground, and ACC as that is the immediate need. Any errors you see? Anything to trouble shoot further? I'm open to the possibility that the CH3 harness is not for this truck/configuration, but the Axxess site lists this harness as compatible. If you've read this far, thanks, and if you read the connection info and offer ideas, I'll be beyond appreciation.
Android CH3 Harness
RLS- Green/black
RPS+ Green
RRS- Purple/Black
RRS+ Purple
ILL Orange
ACC Red/Ignition
Ground Black
Power 12+V Yellow
FLS- White/Black
FLS+ White
FRS- Gray/Black
FRS+ Gray
