Power loss??
cdferry
Here lately my truck has been losing power and killing itself when i let off the throttle coming to a stop sign, it seems to do it worse right after i add fuel. Any ideas on what is causing this.
cdferry
cdferry
Any ideas would help. I have to be at work at 0400 and this is my daily driver so im a little desperate.
Butterflywings85
93 dodge d150, 94 dodge ram 1500
v6 3.9 liter, V8 magnum 5.2 liter
fuel pump ?
fonzyn75
well get a fuel pressure gauge and check your fuel pressure sounds like it could be a fuel problem. If not tap your catalytic converter and see if you hear anything inside bouncing around bc they do get clogged from time to time. If not a nice set of plugs/wires/distributor cap and rotor replacement might help.
