Power steering hose leaking
Pickett235
Ok
The hose from the power steering pump to the hydro boost started leaking at the pump. I have replaced the o ring with one from an auto store and the from the dealership. It is still leaking at the steel fitting at the bottom of the pump. Any ideas on what could be causing this?
aviatorblackout
NC
I had that same problem and just replaced both hoses with ones from a salvage yard on a truck with low miles (mine had 170k at the time). I think those fittings get worn or something, not really sure. Same thing happened to a friend of mine.
