Miles2020
Hi There,
My 2017 RAM 1500 V6 Bighorn Crew cab with 59K miles recently start loss power steering in the morning. I live in Michigan, the temp dropped to lower 60 in the morning. A service power steering icon showed on the dashboard screen. It will get back to normal after about 10 minutes driving on the freeway with complete shut off and restart. Then it will be good for the entire day, and happens again in the morning. I checked the code with INNOVA 3100 ABS OBD II scanner while the service icon showed, it read No Powertrain DTCs or Freeze Frame Data is presently stored in vehicle's computer.
I did some research, 2017 RAM 1500 power steering is an EPS system, there is no pump, fluid in this system. A friend who works at a electrical-hydrophilic power steering company told me it might be a connector issue and suggested me to spay some contact cleaner on 2 connectors on the EPS.
Does anyone have similar power steering issue? Any suggestions to find the root cause?
Thanks,
Miles
Thanks,
Miles
