Doubt you will get many complaints here. But ask us if we think the PW is better than a Raptor!! Lol.
The PW loves the gas station. If the is a small to mid size station it has one sump pump and no regulator, so if you are the only one pumping, the pressure is so great and you have to use the middle setting. Larger stations have 2-3 ground pumps and a regulator to maintain controles flow. Seems to not be able to displace air fast enough when the flow is above average out of the pump.
The hood is adjustable as mentioned already.
Get a 19 or 20 model to get the better tranny.
Don’t join the club if your gonna cry about payload and tow ratings.
Get 35” tires before you leave the dealer lot.
The vibration you may get at cruising speeds is the economy mode forcing the cylinders in to 4 cylinder operation. Common complaint and can be turned off. ( not an issue in my 19. ) good luck.
