Power Windows ?
Micks-hemi
Abbotsford,BC
Hi All:
I have a 2018 Ram 1500,RCSB. It has power windows with the one touch down function. My question is,can one touch up be enabled by dealer or with Alpha-OBD? If not,what is the reason?
Thanks,Mickey
Ricks Ram
Hi All:
Thanks,Mickey
For some reason the regular cabs do not have the auto up function. The dealer cannot enable this for you. The setting should be present with the Alfa tool but I'm not sure what would happen if you set it. I don't know if the Regular Cab master switch is capable of the one touch up option. If you have the Alfa tool you can always enable it and see what happens.
Sent from my SM-G981U1 using Tapatalk
Mister Luck
cassis tutissima virtus
WEST COAST
5.7 V8
My past experience with earlier models with similar features
The actuator itself is specific to the command.
OR
You may need a particular CAN bus protocol enabled card paired with the actuator.
Mister Luck
WEST COAST
5.7 V8
Quad and Crew Models have what is termed as
ANTI PINCH function and there is a section of the owners manual on how to reset the One Touch operation for the front passenger and driver controls outlined as in the provided video from misfit77.
rangemaster728
NW Oregon
3.6L
To expand on that...if you install window deflectors (i.e. Weathertech) part of the install procedure is to cycle the windows several times...holding the button UP to make sure the windows doesn’t reverse.
This not only makes sure the deflector is seated in the channel, but it also appears to ‘reset’ the up torque/force limit on the window motor circuit.
stevenmicheal
