Power without tune?
Tpearson515
Saco, Maine
How much hp gain can these truck get without tuning the ecu or does the computer really limit any bolt on performance mod you add to this?, I have a 2015 with 3.21 8 speed, just curious. It sucks the ecu on these trucks are locked.
raginglaramie
Edmonton,AB
I’d say the only way to unlock any potential horsepower is with the ecu tuned according to what the engine performs by pushing exhaust, sucking air, and squirting fuel. If you got better exhaust you would tune accordingly. You could add everything onto the truck but without an ecu tune you probably would be feeling that the engine is acting funny. But this is just what I think. Anyone want to chime in?
Pull Ya
Cedar Creek, Tx
There are a number of "bolt on's" you can add to your truck; headers, CAI, freer flowing exhaust are some of them. While some of those mod's will not increase your horsepower per say, they will make your truck run better. There is not doubt that a tuner is the best bang for the buck regarding horsepower, especially with a custom tune. If you want better acceleration you can try a Pedal Commander. It will not increase your hp or tq but it will make your truck accelerate faster by removing the "lag" many people experience in acceleration. Also you might think about installing a catch can. Many of the above items will make your truck run better, but the tune is really the piece that pulls them altogether and gives you the maximum performance from all the pieces working together.
Jay
[email protected]
6.4 hemi
I agree about the engine wont feel right. My 11 had minor bolt on's just CIA,catch can, and a drop in 40 series. Without the tune felt like i was driving a 6 cylinder with horrible throttle response. Tune is the way to go. I have a 2016 2500 with the 6.4 i have added CIA and custom exhaust CAT back system. Will be adding 87mm throttle body (Moes) and next PCM with HEMIFEVER tune. IMO the bolt on's just enhance the tune. If your worried about the warranty just get a whole new PCM like im doing and if it has to go to the dealer just swap the stock one back in 10 min job.
raginglaramie
Edmonton,AB
I’m not a believer in the throttle body “upgrade”. Maybe if you are running huge cubic inches N/A with a big cam needing the air. But without a proven dyno sheet stock vs upgrade I’d probably save the cash. Anyone else wanna tune in on this?
[email protected]
6.4 hemi
I have been sceptical as well picked one up used for 275 off here so I wanted to test it my self to see what it is about. I can keep you guys updated if you want. Should have it in on Saturday.
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
Edge has a new one coming out, be interested in seeing how it reacts.
MADDOG
Living in a Firepit
You can add all the bolt ons you want but the PCM, which controls air/fuel ratios, won't adjust to the additional air in and out of an intake and exhaust system. It won't account for the passage of air through a larger throttle body. And it won't increase line pressure in the transmission to firm up the shifts just because you bolted on some parts.
The best way to 1) get the best benefit of your bolt ons, and, 2) optimize the performance of your truck; is to get that programmer and a custom tune.
Tpearson515
Tpearson515
Saco, Maine
Thanks for the input guys, sucks they locked the pcms on these trucks they are expensive!
Gary's Hemi
Walker, La
You will get more out of a pcm swap & custom tune alone than all the typical mods(intake, headers, muffler and tb) combined on a stock tune.
You can do the pcm swap & Diablo I3 for $499 + the price of a custom tune.
68PowerWagon
Dayton, Ohio
2022 Laramie 3500
6.7 CTD
Yeah from the numbers I have seen you only gain about 10-15hp with this upgrade. About the same as a CAI. When you do the tune I think you can get the high end of those numbers pretty easy. There are a few diy threads on here where people have spent a Saturday porting & polishing the stock throttle body & say it is just as good or close to what you can buy.
68PowerWagon
Dayton, Ohio
2022 Laramie 3500
6.7 CTD
Wish it was that cheap with my 6.4... I think it is more like $899 including the custom tune. Probably where my tax return money is going. :)
68PowerWagon
Dayton, Ohio
2022 Laramie 3500
6.7 CTD
[email protected]
6.4 hemi
I contacted Moe's & they said that set up will not work on my 16' RAM 2500 w/6.4. Said I had to use this one:
2015-2017 Ram 5.7 and 6.4 Diablo i3 Tuner & Unlocked PCM
Our Price: $899.00
I believe you are correct. I already have the trinity from my prior truck. Talked with Matt like 620 for PCM with HEMIFEVER tune.
TheM4rxxx
