Stuffpower
From my understanding these are both the same engines but have different power ratings. Why is this?
Most likely packaging size and there is no need for a Wrangler to be able to pull a heavy trailer like a HD truck does. Cooling is factor also, the EcoDiesel they put in the Wrangler is derated for cooling reasons.Frankly I'm at a loss as to why they stuffed a Challenger 392 in the Rubicon and didn't go with the truck version which would still be impressive in a Jeep.
It is not a simple tune.I was just hoping it was a simple tune to jump the hp up to 470. The power wagon is amazing but I wouldn’t be shy about adding simple hp
I am hoping the Powerwagon gets the 6.2l supercharged.I was just hoping it was a simple tune to jump the hp up to 470. The power wagon is amazing but I wouldn’t be shy about adding simple hp
The power an engine makes has nothing to do with how much the vehicle weighs, or how much rolling resistance the vehicle has.They are the "same" engine if you say they are both 6.4L Hemi based applications. Also there is not a huge power difference between the engines as you are only talking 60 HP, which some minor mechanical changes could accomplish easily. The biggest difference in performance comes from the weight difference. You are talking about a 7,000 lb. Power Wagon versus a 5,000 lb. Rubicon....and the weight difference is more than just adding 2,000 lb. in the back of the Rubicon. Rolling resistance is much higher in the PW because of the larger components....harder to turn the heavier axles, etc... This is really true for the comment about the Hellcat having a lot more power....it's 2,500 lb. lighter and MUCH less rolling resistance.
Never made any comment that the horsepower at the crankshaft of an engine somehow "changes" with the weight of the vehicle, but rather specifically stated the "performance" of the vehicle changes based on weight and rolling resistance. If you put two vehicles with the same engine but otherwise drastically different (i.e. Power Wagon versus a Challenger or Charger car) on a wheel dyno they will have a difference in rear wheel power based on driveline loss....big difference between something like a Power Wagon going through a transfer case, heavier driveshafts, larger rear axle, bigger tires, etc..... versus a car. In that case the total weight isn't a big deal but rather the rolling resistance.The power an engine makes has nothing to do with how much the vehicle weighs, or how much rolling resistance the vehicle has.
All of the manufacturers base their HP ratings at the crank.
And just FYI. 60hp IS a pretty big difference in power. depending on the engine of course. my old street car was at about 450WHP on pump gas (93). i wanted to bump up to E85 for some more power gains. right off the bat got another 20WHP out of it. However, i maxxed out my fuel pump.. so i had to replace with a bigger one.. After that, picked up a bit more HP.. but the duty cycle on the injectors was through the roof! so, bought larger injectors. after all that. i made a total of 50 extra WHEEL hp. this is also ringing the engine out to a 8500RPM rev limiter to squeeze as much as i could out of it.
Which also included cams, valvetrain, head work.
Now in the real world the total weight comes into play in addition to the rolling resistance. Again, put the exact same engine in a 7,000 lb. PW and a 4,500 lb. Charger. If both engines put out identical power numbers at the crank the Charger will "feel" like it has much power and be way faster in a drag race (and get way better MPG). That is also why my 185 HP 4 cylinder car has a faster 0-60 mph time than my 410 HP PW.
More power is never a bad thing. Maybe I'm just getting old but always chuckle a little when I see people say the 410 HP Hemi needs more power. I remember in '88 when Chevy introduced fuel injection on the 350s that bumped power up to 200 HP (about a 25% increase from previous) and people were raving about it....even remember truck magazines having a cover shot of the new trucks doing a burn out. That was the standard in power when I was growing up. Then in the early 2000s I bought a Dodge 1500 with the Magnum 5.9L that had 245 HP and thought it felt strong. A few years later I got a Chevy 2500HD with the 6.0L gas at 300 HP and thought it was fast!GEN III HEMI® Engine Quick Reference Guide Part IV
MORE CUBES AND MORE POWER: 2011 – 2021 6.4L/392 HEMI® V8 ENGINE So far in this series, we have covered the beginning of the great HEMI® engin...www.dodgegarage.com
as you can see there is a fair amount of difference between what is in the HD truck and the jeep. face it our 6.4L are in need of an upgrade power wise....
I started driving in the early 70's and I too remember how gutless my 460's and 454's were. I remember when a a 305 made 165 hp and that felt fastMore power is never a bad thing. Maybe I'm just getting old but always chuckle a little when I see people say the 410 HP Hemi needs more power. I remember in '88 when Chevy introduced fuel injection on the 350s that bumped power up to 200 HP (about a 25% increase from previous) and people were raving about it....even remember truck magazines having a cover shot of the new trucks doing a burn out. That was the standard in power when I was growing up. Then in the early 2000s I bought a Dodge 1500 with the Magnum 5.9L that had 245 HP and thought it felt strong. A few years later I got a Chevy 2500HD with the 6.0L gas at 300 HP and thought it was fast!
The 1975 base 350 V8 engine Corvette was also rated at 165 hp.I started driving in the early 70's and I too remember how gutless my 460's and 454's were. I remember when a a 305 made 165 hp and that felt fast
I have no problem with my PWs power either.
Seems plenty capable to me.
But then, I remember when my 1990 5.9L (EFI) Ramcharger seemed powerful and my wife's V6 pentastar has that beat all to heck on HP and Torque...
