puddle light issue
tyallis
I recently noticed that my tow mirror puddle lights (both right and left) are no longer working on my 2015 1500. They are a manual folding mirror. I find it hard to believe that the LED's are burnt out already?? Any help is appreciated.
Thanks in advance.
Mineralram
on my 2013 i had them replaced 3 times both sides under warranty, they are a **** poor design and blow because water gets to them and they short out
Sent from my SM-G930W8 using Tapatalk
VB712
Maxi_built
Va Beach
My turn signals on both tow mirrors don't work anymore.
T
tyallis
Do you know if they just pop out with a screwdriver? My pickup is no longer under warranty unfortunately. Thanks for the reply.
Mineralram
yes they do youd best to buy a replacement to see how its done
Ram Man
FL
2013 Sport
One of mine stopped working but they started working again after I folded them in and then retracted them again (auto fold). The reason they stopped working was because one of the mirror was pushed in slightly causing it to not make a complete contact with the electrical contact.
So I would recommend making sure they are perfectly folded out. Maybe even fold them back in and then out.
Mugster
Ontario, Canada
I had the drivers side puddle lamp (2013) replaced under warranty about a year and a half ago. Now the passenger side is out. I pick up my 2017 next week so I'm not worried about it but do find it strange that these lights are so problematic.
DailyRam
North Carolina
I have replaced all. The new LEDs are better than original. Put some grease on the connection points when you replace them to protect the points from moisture, and they may last longer.
