Pulley
alsup98
United States
2012 Dodge Ram 1500 Sport
I have a chirping noise coming from the engine. It only seems to do it when it is idling or at least I can only hear it when I sit. I don’t know if a pulley or belt needs replaced? Has anyone came across this problem?
MADDOG
Living in a Firepit
Usually it's the idler or tensioner pulley that starts squeaking first.
You can release tension on the belt, slip it off and rotate each pulley individually to diagnose it.
Also, check the underside of the belt. Make sure it's not glazed, too smooth or cracked.
Rampant
NJ
392 Hemi
^^X2
Also, check for any moisture around the water pump, hoses, and general area. It doesn't take much anti-freeze on a belt to make it noisy.
alsup98
alsup98
United States
Thank you. I’ll check with that
alsup98
alsup98
United States
^^X2
Thank you sir
Rampant
NJ
392 Hemi
Thank you sir
You bet. Let us know what you find.
Sent from my Samsung Galaxy S8 using Tapatalk
