rgrbobbyedwards
For those with the bigger trailers, what tires are you towing with? Stock or have any of you made the switch to the 37's? What load rating?
Get E rated if when you buy tires with towing in mind. I run 35sFor those with the bigger trailers, what tires are you towing with? Stock or have any of you made the switch to the 37's? What load rating?
E rated BFG KM3s...35”!View attachment 222187
I really like the Black Series HQ19.
The Black Series trailers and made in Australia and imported. They are one on the few trailers that are designed from the ground up for off-road use.How do these compare in price to the R-pods? I've had my eye on a R-pod ever since they came out. Would be perfect for me and wife and our dog or me and a good buddy on a public land hunt somewhere out of state. This Black Series definitely looks a heck of a lot better.
I did not think they had an E rated neither. Zooming in on @Udy2554 pic, it looks like a “C”.Legit. I don't see the option for a E rated 37 KM3. 37 KM3's is what I was going to go with, however I can't find them in a E rating...suggestions?
If you are going to tow a lot, stick with 35's. If you go to 37's, you are going to loose a lot of torque for towing - unless you regear the backend. If you are doing mostly off road, then 37's are the way to go.
Here is my stock 2020 (stock tires, stock suspension, no bags) pulling a 40' TT with a dry weight of 8,840lbs. The key is to get the WDH set up correctly. This does more for a correct ride than air bags. Air bags will put more weight on the rear axle and actually take weight off the front axle. Using a WHD set up correctly puts more weight back on the front axle and on the trailer axle. Air bags should be used as a supplement only after the WHD is set correctly.
This is legit. Which WDH are you running...? As far as towing a trailer, it would be a few times a year. Would probably be more off roading then towing. If I go 37's, I'll be re-gearing for sure.
