Pulsar and dealership recalls
Ramangs
I have a 2017 ram 1500 with the pulsar and want to take it in for the pile of recall work that is needed, can i leave the pulsar installed and take to the dealer, if i put the stock setting back in will that work and not have issues thanks
ET
Georgiasport
Douglasville, Georgia
I just had mine in last week for the tailgate and driver restraint firmware upgrade recalls. I just turned mine to setting one and had no issues.
HDHNTER
US AIR FORCE VETERAN OEF - OIF
SC
5.7L HEMI
Still have to take mine in for the driver restraint flash, good to have confirmation that I don't need to pull the Pulsar before doing so!
corneileous
Podunkyville, OK
2018 Ram 1500 Limited 4X4
Any of y’all doin this have warranty?
HDHNTER
SC
5.7L HEMI
Lifetime warranty here. I wouldn't take it in w/ Pulsar installed if I was running any other air intake than I am. The AFE Momentum completely obstructs it from view, particularly so being lifted.
KCaudill
The RAM
Blacksburg, Va
I can bet you the tech noticed and made comments on your vin within the shop computer
HDHNTER
SC
5.7L HEMI
Just took mine in to the dealer for an oil change & driver restraint firmware flash. Left the Pulsar on but set to level 1 / stock. Did not remove the Pedal Commander, just turned it off via Bluetooth (mounted discreetly behind dash). No issues w/ PCM updating process.
Ramm5.7
So Cal
2019 Ram 1500 Classic Bighorn
To each their own....
I pull my pulsar and pc EVERY time I go to dealer. Takes 5 minutes for peace of mind.
Of Course I swapped obstructing S&B for a vararam for that very reason!!
HDHNTER
SC
5.7L HEMI
Agreed, for maximum peace of mind.... pulling it before a dealer visit would be best but it's reassuring to know that should you choose to leave the Pulsar installed, it will not interfere w/ PCM updates or flag the tech's scanner. I figured the Pedal Commander had a pass-through circuit design as well so I rolled the dice w/ just powering it off, fortunately it was a good hunch.
Mbrigh3
IG: Stormtrooper_5.7
MD
I am confused on your last portion. You put a S&B on or the vararam... Shoot ive taken mine to the dealer a ton of times with the S&B and they dont say anthing
Ramm5.7
So Cal
I swapped from S&B to Vararam...much more space to access pulsar! I was refering to accessing the the pulsar to remove it NOT the air system on dealer visits
Mbrigh3
MD
Copy.
