Purchasing wheels
Benb
Battle Creek, MI
vest Website to purchase wheels for the 19s?
Seems most don’t have the option for 19rams...
Doxmia
Canada
Basically any 20" + 6x139.7 will work fine. Be very very careful with 18's, the bulk of them will not fit.
Stock offset is just over +20mm so if you don't want that aggressive look of your tire's sticking out I'd suggest staying close to 20mm off set (basically +10-20mm. If you go 0mm it will stick out almost 20mm which still isn't bad at less than an inch)
JB1
Houston, Texas
Search for wheels that fit a 2016 Silverado, the 2019 Rams have the same wheel bolt pattern and hub bore size
BiGMERF
2017 SLT 4x4
v6
hard to find someone who wants 19's..
