Quads to Duals
WilliamS
Tampa FL
Need some clarity as my brains are starting to hurt.
Quads use 2 bulbs H11 low and 9005 high beam and they are attached to a harness from the body of the truck.
Duals are H13 bulb, is the harness coming from the body already the H13 socket?
Im retrofitting some duals to some big projectors and the quads isnt going to work. So all I need is an H13 harness to tap into the wiring to get it running on the HID kit. Also seeing that H13 is a high low bulb, not having that bulb in place will it throw an error?
brianw0048
EcoDiesel
Did you work this out?
