Question about cree lights
blackout11
blackout11
alpharetts GA
2011 R/T
Got them in the turn signals work and brake lights work but the driving light/tail light does not work anyone else use them
JET
Arlington,Texas
1996/2011 Ram 1500 Sport
5.9 Magnum/Hemi 5.7
If there anything like most LED's you might need to switch one. I mean my switchbacks did the same thing until i flipped one and then they started working. Only thing i can think of.
blackout11
blackout11
alpharetts GA
2011 R/T
Yep switched them and i have resistors but now im being told you cant use them as tail/brake lights only reverse lights
LB3711
Trumbull, CT
3.6L V6
it does say
These bulbs specifically fit 3156, 3157, 3056, 3057, 3457, 4157 and other T20 type reverse lamp fixtures
which sucks I wanted to try them. So i guess I won't now. Dammit lol
EJM05
Somers, CT
440 Big Block
SO are these the Brake lights or the Reverse lights?
sullivan
Houston, Texas
Ive never ever seen these used as brake lights, im with trupiano on this.
Again ive never seen them as brake lights but used as super bright reverse lights.
LB3711
Trumbull, CT
3.6L V6
Crees don't work as a multifunction bulb. In our case not as a turnsignal/brake/ parking light bulb. Its a single filiment function like a reverse light
EJM05
Somers, CT
440 Big Block
Ok so these are for the reverse then. Correct? and if I reading it right, he is trying to put them as the brake light?? im a little confused.
EJM05
Somers, CT
440 Big Block
Yea but the ones you have are CREE's.
09SMOKINHEMI
TEXAS
Well that sucks. I just ran into the same issue. Got mine today and was just about to start a thread on this very question. So now what do we do?
Sent from my DROIDX
LB3711
Trumbull, CT
3.6L V6
yes they are reverse lights only( not for out trucks) and hes trying to use tham as the brakelights. They light up for the turn/brake function but not when the parking lights are on. Our reverse light bulb is #921
sullivan
Houston, Texas
Im assuming everyone had the idea and intentions that this would be a good bulb to use in a tinted tail light?
EJM05
Somers, CT
440 Big Block
OK, so what they need to do is return them cause they are not the right ones. But the right CREE's for the brake light and buy the right ones for the Reverse lights.
LB3711
Trumbull, CT
3.6L V6
Hemi dude
