questions for future reference
crazykid1994
crazykid1994
ok so stay away from the head gasket for now. gotcha. ill leave that to if i ever get inside the engine and make it a stroker
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
^That's always an option. :naughty:
However, you should do a compression test on the engine first before you start your work on it. Don't want to dump money on a bum engine when you could just save up money and do a junkyard rebuild.
crazykid1994
crazykid1994
ill look into it. the engine has never given me problems minus the tranny. and its only got like 140-150,000 on the engine if i remember right. regular oil changes full synthetic mobil1 so i dont think anything will come up bad???
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
A fella around here by the name of Johnn123 has the following quote attributed to me in his signature line: You're working on a Dodge, anything is possible.
Remember that.
crazykid1994
crazykid1994
i guess that is ment to be both good and bad? oh is there a good way around having tranny issues in the future? i want to do a swap and put a manual in it but idk how much work that would be. because the automatic in it now has already been rebuilt and i hear that they go alot in these trucks
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
It can be. lol Mostly bad, but sometimes they'll surprise you and not be a ***** like normal.
As for the trans, make sure the cooler line check valve is removed, put a bigger cooler in it and keep up with the fluid and filter changes. That is a good start. Anything else you're looking at doing some light internal work.
Johnn123
Ontario
if i get new rockers and lifters are they just bolt on and go? i can price stuff out for future. i plan on getting a new cold air intake also after i do everything to it. maybe redo the exhaust as it is starting to fall apart. its basicallly wide open just past the cats. a hole rusted in the side of the pipe. haha. sounds sweet tho
First off buy a k&n drop in filter for the stock intake. Stock one is CAI. Good time to upgrade the exhaust :D
Remember that.
+1 Always do that before going into a motor. No point putting money into a bad motor.
Yes that is my sig quote and its absolutely true.
crazykid1994
crazykid1994
It has the drop in filter already. It was noticeably less power and air flow when my k&n intake snapped. And ill go buy a compression tester for it
Johnn123
Ontario
Sure about that? Because the difference that K&n made you wouldn't have been able to feel :p
Good choice with the compression test.
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
CAIs are useless unless you build a custom bumper ram air system. The power you likely heard was just better throttle response and the lovely sucking sound the CAIs make.
crazykid1994
crazykid1994
Idk. the sound difference was noticeable. It got quieter after I went back stock. Than again the truck was running rough and I did swap out the rotor, cap, and wires at the same time. Maybe that's where I gained the power back from
crazykid1994
crazykid1994
I had stepped up from stock wires and cap to summit racing with 8mm wires.
crazykid1994
crazykid1994
need new plastics and anyone know where i can get a nice fog light kit for the truck? gunna paint the plastics black. the little white car is my daily vehicle. i still need to swap in a new core support and see if that also pulls my passenger side quarter panel back into shape or if i need to stretch the frame some for that. id love to do the axle swap under it as i need to redo the axle seals anyways. but thats all gotta wait. also my rear suspension is tight as all hell... i think its got 5 leafs on it. idk if thats more than need be. or if my shocks are just that old as it was previously owned. bumper sits out farther with the new bumper mounts. than again it was in an accident before. anyone know of a hood like this with real scoops?
stevenmicheal
