392DevilDog
- Aug 25, 2019
- 1,940
- 2,903
- Location
- Glasgow, Pennsylvania
- 2015
- 392 Hemi
For 2015...it is the Mega Cab and the box delete trucks that get the 6500lb axle
I just took a quick look at the towing charts from 2014-2019 and it looks like the RAWR on the 2500s bounces around between 6000 & 6500 until 2018. Finally, in 2019 they all go to 6000# (unless you do a box delete in which case you get a few hundred more pounds). Basically, if anyone is shopping and it might matter, check the door sticker as it can be different depending on model, etc.. I suspect the 6500# axles are the same as the SRW 3500 but don't know for sure.
The biggest question is different people have vastly different perspectives on what "struggling" to pull a trailer is. I've personally talked to people that say a certain truck "struggled" to pull a load because it downshifted one gear to maintain 65 mph climbing a decent size grade, then somebody else will say their truck has no issues even though the truck downshift 2-3 gears and can only maintain 50 mph on the same grade. The area of the country you normally drive in also makes a big difference, such as driving around the midwest that really has nothing but "big hills" versus running mountain passes out west.
Look at the power numbers. These trucks are designed to run at 4k rpms all day every day.
When I tow my travel trailer, and I am in the rolling hills of PA I select 3rd gear with tow haul on and let my 392 Hemi set in at 3 to 4k RPM for the trip.
Then it feels like the Big Gas Engine it is.
This is why gas engines get overlooked for power.
When unloaded and going down the highway and thru town...2500 ia as high as it needs to go.
Then they attach a trailer and the truck wants to turn 3500 and they lose their minds.
If you want to feel the power of your truck...select 3rd gear...or even 2nd...and then modulate the throttle. You will see the power come on they way it is intended
OC- your new 3500 dually is beautiful, but I'm shocked it only has the 3.73s. That's got to be one of the reasons it was at the dealer so long. I don't know who would order a gas powered dually with 3.73s evenwith the 8 speed. Just crazy.
My 2018 3500 is GAWR is 6000, RAWR 7000 and my GVWR 11,700 this is on my 3500.
Yeah my rear axle is 6500 also. Front is 5500Ok that's good info to have big daddy, thank you. Glad to see you back here again.
Looks like your rear axle is heavier than mine or they just gave it 500 lbs more rating in the 3500. It would be really interesting to see what the part numbers are for those axles to know for sure.
How is that 3500 Cummins treating you? Any issues? Do you still like it?
My 2015 has 148k. Your supposed to drive these trucks ya know.Currently have a Ram 1500 Express Crew Cab and looking to go to a 2500.
Came a across a 2015 RAM 2500 SLT with 93,000 miles. That seems like a lot of miles for a used truck. Any thoughts?
Thanks, buddy! According to KBB it's a good price and I could use the extra muscle.My 2015 has 148k. Your supposed to drive these trucks ya know.
Would not hesitate to buy that truck if the price and options are right.
Thanks. This will mostly be used for pulling our travel and utility trailers.My son has a 2018 2500 6.4 with 87,000 on it with about 7000of that towing his 8000lb travel trailer and other than regular maintenance (brakes, oil changes, etc) he has never had an issue
It is only showing 2020 and 2021great link, and on that page found a pop up of all the years so others can pick an choose there year. click the TOWING INFO in the center of screen...
