Quick LED resistor question
S.falcon
Which wires do I splice into with the resistor? I have 2 white with green (outside wire and middle) and a black (outside wire) these LEDs have given me so many problems Im abou to scrap them altogether!
S
S.falcon
That's for my rears.. Green/white for both wires.. The front has a green/white and a blue/white, need to put resistors in both
S
S.falcon
Quick update.. Figured out which wires were which, wired in the 6ohm 50watt resistors and still have hyper flash? I must have wired them wrong I guess
BlackedOutHemi
DFW, Texas
2012 & 2012
5.7L HEMI & 6.7L Cummins
Did you do the right wires? The resistor needs to attach to the ground of the light, and then the positive wire of the turn signal. From a post a while back, I believe Blackout11 said the wires would be the outside ones.
blackout11
alpharetts GA
2011 R/T
First off you only need to do the rears and if the plug is in your hand youll want to tap into the 2 out side wires leaving the middle wire alone the resistor is just a loop so try that and that should fix your prob
scott2488
Olney, IL
I found out with my tails, you have to push them in all the way or you get hyper flash and light out issues
S
S.falcon
Thanks guys going to give it another shot, probably wired them wrong
S
S.falcon
So put them in on my taillights.. As soon as I hooked up the resistor it shorts the bulb and it goes out.. Take the resistor off, light works... Tried 3 different resistors and all the same thing.. Didn't even bother trying the front switchbacks, just too frustrated... So back to v-LEDs everything goes tomorrow along with a phone call and email to let them know how completely disappointed with their service and products I am?. But thanks to you guys for all your help
