RA2 SiriusXM
dav8388
Summerville, SC
In limbo between trucks
3.6 pentastar
I tried to search but came up empty for my exact question. My truck has the RA1 with Bluetooth but no satellite radio. I am swapping it out for an RA2 that has the connection for satellite radio. Do I need a separate tuner for it to work of does the antenna plug directly into the radio with nothing in between?
JOHRY
Ontario, Canada
EcoDiesel 3.0
The RA1 has SiriusXM. My truck had that. If you don’t have it now, you may not have the antenna (it will be a little puck on your roof)
dav8388
dav8388
Summerville, SC
3.6 pentastar
No it does not. I know I'm gonna have to get an antenna. I just don't know if there is a tunner between the radio and antenna.
dav8388
dav8388
Summerville, SC
3.6 pentastar
My radio looks like this. With the phone buttons to the right of the screen.
dav8388
dav8388
Summerville, SC
3.6 pentastar
So I figured I'd update this thread on my findings incase somebody else is looking for the same information I was. The tuner is built into the radio. I found out my original radio was called a UA1 my mistake for calling it a RA1. All I used was a small aftermarket antenna with an adapter to the factory connection on the back of the radio and it worked perfectly. IMG_20180525_142746.jpg IMG_20180525_143540.jpg
The back of my original UA1
stevenmicheal
