Ra4
Status
Not open for further replies.
GYSOT
2014 Ram 1500
Cleaning out the garage and going in a different direction so selling a 2016 RA4. Pics to follow and I don't know how to add different items in the same post so look for other posts for bezel, center console overhead etc.
Asking 525 which is paypal, insured and shipped.
You should add this to your op ...
DIY: 2013+ RA3/RA4 8.4" Radio Conversion Upgrade
Mpgrimm2
Supporting Vendor Navy Badge
SC
2022 Ram 1500 (5th Gen)
5.7L
This is a great price on a 2016 RA4!
Glws.
Sent from my LGLS991 using Tapatalk
blkbaretta
TN
What year did you have this installed in?
I'm curious if it will work in a '14 non-nav 8.4 truck.
G
GYSOT
2014 Ram 1500
I have a 14 non nav truck and it will work. You will need the 911 antenna delete.
blkbaretta
TN
Would that be needed if I already have the shark fin antenna? My truck already has an 8.4 (RA3?), but no nav.
G
GYSOT
2014 Ram 1500
Then no should work perfect let me check with MPGRIMM2
G
GYSOT
2014 Ram 1500
If you have the dark purple connector and again we both believe you should, you are good to go
Mpgrimm2
SC
5.7L
If you have the shark fin antenna already, you won't need the 911/cellular bypass plug.
This would be plug and play for you in about 10 mins. And since you already have an ra3 with uConnect access attached to your VIN (if you even use it), you can likely call uConnect and get them to activate/transfer the service to the ra4 in your truck.
(None of us that upgraded from non uConnect radios, RA1, RA2 are allowed on the service by FCA)
PS: what year truck do you have? You signature is out of date.
Up All Night Sleep All Day via my LG G4 on Tapatalk
blkbaretta
TN
Thanks guys...my truck is a '14.
Gysot...pm'd.
ATOM
So i got a 2016 2500 tradesman with the 5.0 . Is it possible to swap bezels and use the oem volume or am i reading this wrong? Would i the special bezel or steering wheel controls to adjust volume?
WadXpress
HEMI
You would need steering wheel controls or the other bezel.
Booms
The OG
Ocala
2015 Express
Whipple 5.7 • SmoothBoost!
*waiting patiently for listing* :crazy:
Mpgrimm2
SC
5.7L
That's rather messed up advertising in someone else's for sale thread don't you think?
TXbigboy92
HEMI 5.7
Is this enabled for Rear view Camera connection? I have 2013 that has the 8.4 but doesn't have NAV or REAR VIEW CAMERA... ONLY SENSORS.
GoatLocker
Cummins 6.7
Tempting upgrade.
Did you verify the USB port is working (for map/firmware updates)?
R.L.K.
Bristol , Tn.
Your 2013 is backup cam ready Sir . You just need to install the OEM Backup cam kit & get a dealer to flash in sales code XAC .
G
GYSOT
2014 Ram 1500
Tempting upgrade.
No but Nav Repair says it can be done and Sit things he might know and has one coming this week to test
WadXpress
HEMI
Yes you are correct, it was late and I wasn't thinking. I edited my post, I apologize to the Op wasn't trying to take any perspective buyers from you.
Free bump. Good luck with your sale
TXbigboy92
HEMI 5.7
I would like to know how to verify this.
I Already looked and mine only has two wires going up to the front from the tailgate connector.
I heard this means it does not come prewired. as camera ready ones will have 8 wires going up to the front instead of just the tailgate lock, which has two. Like mine.
Status
mikep345
