I was able to pull out the leaking rack and pinon within a couple hours. Very straightforward. The only part that I struggled with was disconnecting the steering column shaft to the top of the rack and pinon. I used a prybar and the frame to push the top of the R&P down. Some pressure and a couple knocks got it to separate.
However.... now I can not get the new R&P installed. The steering shaft seems to be too long. If i bolt the R&P to the frame then the steering shaft is too long and I cannot get it to slide over the top of the R&P. If I put the shaft over the top of the R&P then it does not sit flush against the frame so that I can bolt it in.
I'm afraid the steering shaft was pulled down somewhere. Has anyone replaced one of these or been through this before? Or anyone have a suggestion where it could have slipped?
Thanks for any help.
