- Nov 2, 2020
- 10,127
- 12,744
- Location
- El Cajon Calif. 92021
- 2016
- 3.0 ecodiesel
just remember, your garden hose has at least 50 pound of water pressure.
your vehicles coolant pressure is no more than 12 pounds
so keep your back flushing pressure down low, many times radiator shops will use air pressure to blow the water out of the HVAC heater.
Once the water is blown out, the lines should be at least partially open
You can then use RMI 25, as mentioned above, or some people choose to use CLR, which is very acidic.
Youtube has several videos on back flushing
The HVAC BOX is under the dash
if you remove both Glove Boxes, you can see 2 of the HVAC Actuators
#1 is almost straight back from the upper glove compartment,
it allows fresh air to enter the cab
#2 can be seen through the lower compartment box, by looking to the left, using a flash light is easiest.
( you can work the controls & watch the actuators work
#2 is called the BLEND DOOR
numbers 3 & 4 are called the MODE doors
3 & 4 Actuators are hiding behind & below the HVAC Controls
you have to remove the center stack that surrounds the radio to get at them
watching a YouTube video really helps to get at them
if you have a full floor console, it is quick & easy
each actuator is held onto the HVAC box by 2 screws
the rod that is connected to the actuator, is also connected to the door that is inside the box
