Radiator support headlight bracket
Caleb langley
I have a 2012 2500. I had a little fender bender and I'm trying to replace some of the parts. I'm needing the headlight mounting bracket but the only way you can buy it(that I've seen) is in one complete unit that includes the radiator support and Lh/Rh Lamp mounts, even though it unbolts from the unit. Does anyone know of where I can get just the driver side mount or has someone ever been in this situation for the passenger side and have the driver side leftover
C
Caleb langley
No that's the part the back of the light pops into
C
Caleb langley
This is it but this is for a 2013(they made them separately from the radiator mount in 1e
3)
C
Caleb langley
From what I'm seeing I have to but the whole unit like this
zeddy
Burbank, Ca
Have you tried junkyards in the area? Call a few places. You might get lucky
C
Caleb langley
I'm needing this bracket. They don't sell it separate from the radiator support for some reason.
C
Caleb langley
Is that under a different listing then the radiator support? I might be looking in the wrong spot
C
Caleb langley
This is the only number that's on that Particular piece dunno if it's a part number though since it came with the radiator mount
wgreggking
rural Arizona
2017 4x4 offroad
use this as your search term then you may find sub parts or partial, 2500 and 1500 are they the same in 12? good luck dodge ram headlight bracket radiator support
C
Caleb langley
Ok sounds good. Thanks for all the help. I may buy the complete one you found that price beats 500$ for a new one
C
Caleb langley
I really don't know if there is a diff between 1500/2500
TheM4rxxx
