Radio range
pinenut
Whitehorse
The factory radio in my '98 Ram Roadtrek has three or four times the range of the actory radio inn my '10 1500 Laramie. Anything I can do about it? Like a different antenna? I'm usually on FM catching the news, not much into music since my hearing went to hell.
Thanks
How can I boost my FM radio signal in my car?
How to improve radio reception in Cars/Home?
  1. Use a quarter-length antenna (32 inches) for your car. ...
  2. Change the position of the antenna. ...
  3. Use a signal booster or a pre-amplifier.
  4. Use diversity tuning.
  5. Ensure that the antenna mast is extended.
  6. Check antenna connections.
I have not looked at a Radio for 40 years
On radios back in that time, had a hole on the side of the case, the hole was usually on the same side as antenna cable plugged into.
Inside of that hole was a small Phillip's screw
That screw could be adjusted to bring in the local FM stations.
I never turned the screw far & I counted the distance the screw was turned
If it did not increase the clarity going clock wise, then i returned go back to the factory setting & turned it clockwise.
If that did not improve the reception, it had to be returned to the factory setting.
Today, our radios are half Radio & half laptop computer
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
Thanks
Personally, I feel this is intentional to push SXM subscriptions. I have anecdotal proof, but the 2013-2017 8.4 has better reception/HD radio quality in the same truck as the 2018+ radios. At the very least, it's not at the top of their priority list.
The best way to improve radio reception if all connections are solid is a longer antenna.
stevenmicheal
