johnjoseph131965
Looking for some advice/ideas. I have a 2018 Ram 1500, 3.6 vvt, 15k miles... I have experienced an intermittent problem with the steering. The wheel vibrates/shudders when turning at low speeds, i can feel ‘drag’ in the wheel while driving, but not the noticeable vibration. Seems to start to occur when I have backed up and turned the wheel?? There is also a grinding noise that accompanies the vibration, which to me sounds like gears clashing... The problem has popped up two or three times and the just goes away... At first I thought that it was stuck in 4wd for some reason, as the steering has the same feel as being in 4w low, but that is not the case....
Anyone with similar problems or ideas of a possible cause?? The truck has no hard driving, mostly highway miles..... Any help appreciated!
