Ram 19
FuqARam
Tennessee
I have a 19 ram 1500 bighorn and my headlights, taillights, tag lights all flicker when the ignition is in the run position nothing works highs don’t fogs don’t nothing just flickering low beams, how ever when I turn ignition off and put the ignition in accessory mode everything works as it should I have new bulbs and battery seems fine this has been going on for a few years and can’t figure it out please please help!
G-Ride990
Administrator
Chandler, AZ
5.7 No E-torque
Does everything work when the truck is idling?
Welcome to RF!!!
99 times outta 101 it's gonna be the ignition, some can be taken apart and cleaned. I don't know if they still using win module for 2019, but whatever they are using I'd look at ignition first.
F
FuqARam
Tennessee
Ok because it only does it when engines running on ignition is in the run position without motor running and for whatever reason I cannot get fogs to work at all
You mentioned that all BULBs are new ..
Did you replace them with the original bulb type or did you do a Up Grade
F
FuqARam
Tennessee
Was a up grade but the factory halogen do it to witch is y I swapped them out
EdGs
FL
Headlamp switch would be something to check.
Mine failed in my '15, but I didn't have any flicker, just out in 1 position.
That being said, it is an electronic part and bad solder joints and such can cause funky issues.
Definately sounds like a loose connector/ bad connection, tho.
Did you go led? You need to get a balast or similar if you upgrade to led.
F
FuqARam
Tennessee
Yea I’ll have too go to that next then probably ignition and bcm I guess until it fixes
F
FuqARam
Tennessee
Yes but has them built in I bought the silvaina leds with that built into the wiring
Did they flicker before you switched the bulbs?
