Ram 2019 Classic RA2 to RA4 Upgrade
WileECoyote
Charlotte, NC
HEMI 5.7
Thanks to MP Grimm and everyone on this great forum I have upgraded several things on my 2019 RAM including the radio to an RA4. But the radio is a 2014 and unfortunately has V1 of the maps. I would like to upgrade, but first I would like to see if our address is listed. We live in a new development that is a little over a year old. Our house address is around 8 months old.
If someone has the latest version (I think V10) and would be generous enough to check my address please PM me.
Thanks again, this forum is awesome!
Mpgrimm2
Preferred Vendor
SC
2022 Ram 1500 (5th Gen)
5.7L
I can't find your info in my notes and a few of use are wondering ...
Is that a 19Ram 1500 Classic ?
Which HVAC module PN did you use?
Which Ra4 VP4-NA radio PN & year?
Factory 4 /7 speed fan?
Factory radio?
FYI: @Ricks Ram , @STecoD , @Dodgetk81 , @DeereGuy
M² Mods.
WileECoyote
WileECoyote
Charlotte, NC
HEMI 5.7
You're working on my cable now... :) (Charles)
19 RAM 1500 Classic
HVAC 68366552AA
RA4 VP4-NA 68224525ZJ (2014 Cherokee)
7 Speed Fan
RA3 Factory Radio
Mpgrimm2
Preferred Vendor
SC
5.7L
Doh !?! Brainfart. It's in progress on the bench at home. (I'm at work).
... (I moved the email/info into my in-work folder!).
Edit: and believe you started with a factory RA2 5.0 radio.
M² Mods.
WileECoyote
WileECoyote
Charlotte, NC
HEMI 5.7
Yep... I fat fingered it and didn't catch it... yes, RA2
Edit: And no worries on the brain fart. You assist so many here I imagine it's hard to track all the usernames. We appreciate all the help!
Mpgrimm2
Preferred Vendor
SC
5.7L
Harness is on its way. Curious how this mash up of different year parts will pan out
M² Mods.
WileECoyote
WileECoyote
Charlotte, NC
HEMI 5.7
Thanks Mike!
I agree...
2019 Ram Express Classic
2014 RA4 Jeep Cherokee Radio (68224525ZJ)
2018 HVAC Module (68366552AA)
2016 RV Mirror (68096091AF)
2018 Mirror Harness (68343002AA) w/Humidity Sensor (55111389AF)
2018 Temp Sensor (55111178AC)
13-18 Auto/Temp Bezel?
I have already installed the radio and steering wheel mounted volume controls which have been working perfect (except the 911 message.) I will let you know when all the other parts are installed. You wanted me to test the manual temp control first, before converting to auto?
Mpgrimm2
Preferred Vendor
SC
5.7L
Yes please test blend door/HVAC travel before enabling single zone ATC. If you leave the lower glove box out, you can watch to see if it has full travel in both directions as you adjust the temp up/down (watch the white tab move).
Reference first 5 posts and last few ...
- HVAC problem with UAS upgrade (see ATC thread).
You can see 2 example videos of what to look out for here...
(Jumpy On screen slider)
(Temp Blend door travel)
M² Mods.
WileECoyote
WileECoyote
Charlotte, NC
HEMI 5.7
Installation went smooth, most everything is working great. I checked the blend door before enabling single zone ATC and it worked fine. I tested both directions several times and it went to the ends.
The only issue is the 911 message is still popping up.
Mpgrimm2
Preferred Vendor
SC
5.7L
Thanks for the update. Now we are left to wonder if adding the sharkfin would resolve it or not. Did you use a 13-16 mirror with mics vs a 2018?
Let see some pixs !
WileECoyote
WileECoyote
Charlotte, NC
HEMI 5.7
Yes, the mirror is from a 2016 w/mics. Maybe I should try a 2018 mirror w/o mics?
Here are a few pics I took along the way...
Mpgrimm2
Preferred Vendor
SC
5.7L
Thanks Mike!
I agree...
FYI,
Managed to find a deal on a 17 Ra4 VP4-NA radio to test in my 18 Laramie to see if the full 18 setup works with it (HVAC module, assist mirror, Sharkfin). Will let you know how it goes.
EDIT: no cell error message in my truck... But I do get the jumpy/erratic temp up/down slider slider with the factory 2018 1500 HVAC module (xxxxx552Ax ). 14-17 HVAC module works fine with the Ra4 in my truck though? See a few posts down.
Seems inconsistent on mixing RAx year with different HVAC module years after getting reports from others.
M² Mods.
Mpgrimm2
Preferred Vendor
SC
5.7L
WileECoyote
WileECoyote
Charlotte, NC
HEMI 5.7
I compared my BCM setting with MPGrimm's 18 Laramie and found two that were different. Interior EC Mirror Present and UConnect Access Mirror Buttons Present. I set both to 'Yes' and now I have two more buttons on my Apps screen (Controls and Mirror Dimmer). Unfortunately the 911 error message is still coming up.
Mpgrimm2
Preferred Vendor
SC
5.7L
I installed the 2017 Ra4 VP4-NA radio I just picked up and it's not showing any issues whatsoever in my 2018 Laramie with factory 8.4 UAS radio & Dual Zone ATC.
I did have to install a 13-17 HVAC module I had on hand (68183973AA) to get the temperature sliders/control to work. No issues on my drive to work (No cell system error, etc).
14-17 1500's w/RAx = 68268186Ax HVAC module.
(Alt: 68183973AA, 68236772AB, AB, AC, etc.)
>> 18's 1500's w/UAx = 68366552AA HVAC module
4bfda90aca448a113c043cccac16dcd3.jpg1c5aba7040e1e0c4d33f7e6aa9a55497.jpg086004c2a9777d1bd1a2cf69d55074f4.jpg1755d100df8d0e8b6b0d75437295ade9.jpg452ef3a2042ca897c82f61a5eee5f107.jpg
M² Mods.
WileECoyote
WileECoyote
Charlotte, NC
HEMI 5.7
Very interesting... I just verified that I do have the 2018 HVAC module (68366552AA) and it is working with the 2014 Cherokee radio.
I just noticed the back of my radio has a pink plug. Should something be plugged into it? I plugged the 911 by-pass into the purple plug.
