Ram 2500 3.73s or 4.10s
RamGuy110
2022 Ram 2500
So, I'm looking to downgrade to a hemi from a cummins mainly for cost, etc. My payment would decrease significantly. I found three Laramie's that I am considering. Only one of them has the 4.10s though. I tow 2-3 times per week, less than 100 miles round trip each day and the weight is usually from 6,000-9,000 pounds. I would ideally like to level it and put on 35s or 295/60/20s.
I know that 4.10s are the better choice, but the two trucks with 3.73s are better equipped than the one with the 4.10s.
Do you think it would matter much if I just went with the 3.73s and put on 295/60/20s, leveled it and do towing thats well below the 14,000 lb threshold that they have?
69GWC
Power Wagon
Spring hill, Kansas
2022 Power Wagon
6.4 Hemi, 8sp
Tough to say, my PW has 4:10s on the stock 33s, it pulls my camper that’s about 7500lbs super easy, I plan on going to 37s on it.
With that said with out doing all the math (comparing mine to what your looking at)you going to 35s would not be something I thing would be to bad as the 8sp has a real low first gear.
Lower gears are better though no question
69GWC
Power Wagon
Spring hill, Kansas
2022 Power Wagon
6.4 Hemi, 8sp
Shoot my last truck had 3:21 gears with 35s and pulled the same camper easy as well. No mountains around here so can’t say about that. Lol
JCE
Idaho
I had the same internal conundrum. I ended up with a Laramie loaded with a long box and 3.73s. Hard to replace options where as you can always regear.
Dean2
Near Edmonton
ReGear is 1500-2000 minimum for parts and you do the work. Double to have it done. I specifically ordered 3:73. With tow haul, gear selectability and the power of the 6.4 it will pull fine. Going to 4:10s will up your RPM about 150 at 65 mph. You will not feel any difference off the line.
mtnrider
Georgia
Does the hemi have a 6 or 8 speed (not sure what year you are looking at). Given that you are towing and going up to 35's I would definitely lean towards the 4:10 gears myself.
RamGuy110
RamGuy110
2022 Ram 2500
I've priced re-gearing and I'm getting close to $4000
RamGuy110
RamGuy110
2022 Ram 2500
8
gofishn
Iowa
hemi 5.7L, 345 cu in
As said, buy the better truck.
Gears are cheap and easy to do.
I had 3.73 in my 2500 and would pull anything with zero problems but i had teh V-10 too
Irishthreeper
I doubt there’s much difference towing between the 2 but I do really like my 4.10’s pulling 10-11K lbs.
RamGuy110
RamGuy110
2022 Ram 2500
If the one with the 4.10s wasn't 3 hours away, this would be an easy decision!
buckeyexx
Ohio
2016 Power Wagon
I went from a 3.73 in my old truck to a 4.10 in my power wagon. I can tell a difference between the two for sure especially the shifting pattern. The 4.10 seems to hold the gears a little better than the 3.73 and torque feels better. Is it a world of difference and a deal breaker I don’t think so but if I had the choice between two trucks that were identical other than gearing I would opt for the 4.10.
RamGuy110
RamGuy110
2022 Ram 2500
I've towed with both and I agree, the 4.10s just handle it better.
Noneck
2013 Ram 2500 Laramie. 35's 2 inch level. Raceme. Fully deleted 5 inch FlowPro Exh
Ahh the great decision! I have a 13 2500 Laramie Cummins which came with the awful 3.42 gears. Been trying to make up my mind and debating gear choice for a couple years now lol! 3.92 would be perfect it they don't make em. I have 35s and a 9k RV that I tow occasionally. My gut tells me to do the 4.10s, I just worry about HWY rpm. Ive also considered a power wagon but but they only have a 9k max tow rating.
