Ratman6161
I have the 4.10's but confess Ive never driven one with the 3.73. But I don't regret the 4.10's. The primary purpose of my truck is towing the travel trailer - about 7,600 loaded. Of 7000 miles on the truck so far, about 5,000 have been towing so I lean to optimizing for that. My theory about engine RPM is as follows: The transmission will downshift to a gear where the engine is at an RPM where it can deliver the required torque for the circumstances. If I had the 3.73, when towing the trailer, it would just downshift more because the required engine RPM is the same; it would just need to be in a lower gear to get there. With the 4.10, its more likely to be able to stay in the higher gears. Where the 3.73 would be better is when not towing. Then it would be able to cruise at a lower RPM when in 8th gear on the highway leading to better MPG. So its optimized for towing or optimized for MPG when not towing...thats the choice. For me, the 4.10 was obvious.Ahh the great decision! I have a 13 2500 Laramie Cummins which came with the awful 3.42 gears. Been trying to make up my mind and debating gear choice for a couple years now lol! 3.92 would be perfect it they don't make em. I have 35s and a 9k RV that I tow occasionally. My gut tells me to do the 4.10s, I just worry about HWY rpm. Ive also considered a power wagon but but they only have a 9k max tow rating.
Example: The gear ratios for 6th, 7th, and 8th on the 8 speed are 1:1, .84:1, and .67:1. Calculating the final drive ratio for those gears with
3.73: 3.73:1, 3.13:1 and 2.5:1
4.10: 4,10:1, 3.44:1 and 2.74:1
So suppose that when towing, im in a scenario where my truck needs 7th gear. With the 3.73 you might not have enough torque in 7th and have to drop down to 6 - in which case the truck with the 3.73 would be running at a higher RPM than the truck with the 4.10 since it would be at a 3:73:1 final drive ratio vs 3.44:1 for the 4.10. At least that's my theory
Note: these numbers are ignoring the effects of tire size as for me the tires would have been the same either way.
See here: https://www.tremec.com/calculadora.php
You can manually put in your numbers since we don't have Tremec transmissions. There are various other calculator's on the web
