PCT
2019 2500 6.4
- May 9, 2014
- 2,107
- 475
- Location
- Northern California
- 2019
- 6.4
It says right on the bottle limited slip, is there anything I can assist you with past that? Quote me or phone call me @Burla if you need something. 75w90 is pretty much universally known as the weight for most applications, 2500's and above for sure. 75w140 is for 1500's only. Many years ago the industry decided that modified gear fluid is also fine for open diffs, so generally speaking most gear fluids are universal, just find the viscosity you want. The exception for some is if they really want for their manual gear box to use a gear fluid that has NS in the title, meaning "non slip". Now, there has been no movement in gear fluid specs for 20 plus years, so 2002 specs are still in effect today, if it says gl-5 then that is what is used in most if not all diffs this century.I cannot find a clear answer on weather what the fluid is. i found a few sources pointing me to 75-85. 2019 Ram 2500 with LSDView attachment 470032
lol i know that, i meant the weight of oil, im not sure how to confrim the size of my rear end, or is it all 2500 have 11.5. or do some have 12.0? I am like 90% sure but just want to x2 check before full sending.It says right on the bottle limited slip, is there anything I can assist you with past that? Quote me or phone call me @Burla if you need something. 75w90 is pretty much universally known as the weight for most applications, 2500's and above for sure. 75w140 is for 1500's only. Many years ago the industry decided that modified gear fluid is also fine for open diffs, so generally speaking most gear fluids are universal, just find the viscosity you want. The exception for some is if they really want for their manual gear box to use a gear fluid that has NS in the title, meaning "non slip". Now, there has been no movement in gear fluid specs for 20 plus years, so 2002 specs are still in effect today, if it says gl-5 then that is what is used in most if not all diffs this century.
api gear fluid specs
Yeah you do. Hint: EPAThe difference between 75w85 and 75w90 is the 85 would be 5w30, and the 90w would be 5w40. Now, the formula is different, you don't want 5w30 or 5w40 in gears because of EP additives, many of those cant be in gears like moly. I for the life of me dont know why they would spec the "5w30" version for a 2500 that tows. For the longest time all you see is 75w90 for diffs. A little more protection.
If only it told me where my truck was currently sitting at. It was supposed to ship 9/21 but who knows.
